Author Topic: 26 ew mag rebuild  (Read 3374 times)
Offline Simon Giles
26 ew mag rebuild
« on: 12 Apr 2016 at 23:08 »
Hi Team,
I'm getting the magneto rebuild.
How many rollers should the magneto drive bearing have?
Cheers,
Simon
Offline Simon Giles
Re: 26 ew mag rebuild
« Reply #1 on: 14 Apr 2016 at 02:03 »
Hi All,
Further to my question yesterday please see attached photos.
Is this magneto drive as per original design or has it been modified?
Are one or more roller bearings missing?
Thanks for you comments/assistance.
Cheers,
Simon
« Reply #2 on: 14 Apr 2016 at 07:24 »
Simon,
            I can't comment on whether the bearing has been modified or not, but the normal practice for crowded balls or rollers is to have a 'full house minus one'.
Offline Simon Giles
« Reply #3 on: 14 Apr 2016 at 08:41 »
Thanks Eddie,
We are just not sure it we are missing one roller in the crank case somewhere!
« Reply #4 on: 15 Apr 2016 at 16:28 »
Simon,
There should be a brass cage holding twelve 3/16 x 3/16 rollers. Though I am missing it, the book also mentions a fiber washer used as a face seal. There should be a spring and plunger in the end of the drive dog to keep the fiber washer under light axial pressure. I think I have the cage assembled the wrong way around in the accompanying photo. I doubt they would have the ends of the rollers open to the magneto gear.
Offline Simon Giles
« Reply #5 on: 16 Apr 2016 at 01:58 »
That's very helpful Doug-  thanks it gives us something to work from.
Simon
