Author Topic: Valve Cotter Pins  (Read 1613 times)
Offline phil_h
Valve Cotter Pins
« on: 22 Feb 2016 at 17:32 »
Evening all.
I'm at last in the final stages of my 2+3/4 engine rebuild and I need to make some new cotter pins.
The last material I used was obviously rubbish, as they were bent before I removed them and broke in the process.
Does anyone have a recommendation of the best material and somewhere that supplies it please.
phil
Offline IPalmer
Re: Valve Cotter Pins
« Reply #1 on: 22 Feb 2016 at 18:12 »
Hello Phil,
I ended up using roller bearings:
3x11.8mm Rounded End Loose Needle Rollers from Simplybearing_uk as purchased on Ebay. I think they are £9.60 for 10.
No sign of any wear as yet, and my 2 3/4 is no slouch! It's the Zoom Zoom exhaust that helps.....
I hope this is useful to you.
Ian
Offline phil_h
« Reply #2 on: 22 Feb 2016 at 19:58 »
Thanks Ian, I think I'll try those.
I think I used spokes before, and wasn't happy with the results.
phil
« Reply #3 on: 22 Feb 2016 at 20:43 »
I use HSS drill bits. When making a new valve I buy a new HSS drill bit, drill the hole, then cut a pin off the chuck end of the drill with a thin cut-off wheel in the Dremel.
