Author Topic: 26 Ew advice  (Read 1281 times)
Offline shuswapkev
26 Ew advice
« on: 19 Jan 2016 at 10:20 »
the timing end of crank   is that 19 x 1/2?   I can get that set from tracey,s
I have to make an oil pump gear...any advice??
the peg that goes into the vertical oil pump shaft..the gear rubs against...can I get a picture of that..does it go thru the slot in the pump casting
thanks
