Author Topic: Spokes 11 gauge?  (Read 5299 times)
Offline ste
Spokes 11 gauge?
« on: 04 Jan 2016 at 18:12 »
Me again!! Can't seem to find spokes for the front wheel of my TS project.
Two questions please:
1. Am I correct that the spokes should be 11 gauge? I've measured a rear one at 2.97mm but have no original front ones to measure.
2. Is there a supplier out there for spokes to suit? Preferably galvanised as I'm painting them black.
Stephen
Just read a thread from Chris, from 2006,  stating 11 gauge was unavailable. Is this still the case and by the sound of it, I'll need to go to 12 gauge being the closest fit?
« Last Edit: 04 Jan 2016 at 18:21 by ste »
Offline RockDr.
Re: Spokes 11 gauge?
« Reply #1 on: 05 Jan 2016 at 07:33 »
Try local first and give these guys a call
http://www.vintagerims.com/home_Vintage_Rims.html
if no luck  then you can get spokes from
http://users.chariot.net.au/~brianforth/BeadedEdge.htm
I use these without problems.
« Reply #2 on: 05 Jan 2016 at 09:11 »
Hi
When I posted that 11 gauge spokes were not available I was only referring to the main UK suppliers of spokes. I have since seen a later message suggesting that these were available from a supplier in Australia. I have not followed up on this.  On all of my restorations of 2.3/4 hp models I have used 12 gauge spokes with no problems. However, on one machine on which I later attached a sidecar I started to experience spoke breakages and as result rebuilt all three wheels with 10 gauge spokes. No problems since. This situation is not unexpected as the loading on spokes forced to remain vertical while the bike is cornering is obviously much greater than when the spokes remain in line with the angle of banking. Chris.
« Reply #3 on: 05 Jan 2016 at 21:06 »
I find these guys very easy, cheap and helpful:
http://www.newsonsportec.com/
They have all sizes, including unusual sizes like 11g and 13g, and do steel, stainless and pre-finished (e.g. black). Best to state exactly what you want - length is measured from the inside of the spoke elbow to the end of the spoke. 90 degree is OK for both inners and outers for a veteran/TS wheel. They deal on ebay http://www.ebay.com.au/usr/laloma123 , and on the occasions I have used them will just list your (custom) spokes on ebay and you buy them in the usual way. They also supply nipples, but typically only one barrel size for each gauge.
One of the few areas of restoration that has got easier!
Offline joeis6
« Reply #4 on: 07 Jan 2016 at 10:11 »
len reynolds in chch can do them
neale
Offline ste
« Reply #5 on: 07 Jan 2016 at 17:26 »
that would be great. Do you have a contact number please?
Stephen
« Reply #6 on: 07 Jan 2016 at 20:39 »
"chch" - ah you New Zealanders talk funny. I did figure it out, but it took a while!
Offline ste
« Reply #7 on: 08 Jan 2016 at 00:58 »
Are we going to start the eternal Kiwi versus Aussie debate here?
« Reply #8 on: 08 Jan 2016 at 07:49 »
No.  :D
Offline joeis6
« Reply #9 on: 08 Jan 2016 at 08:59 »
Len Reynolds
unit 1
71 Buchan st
i have no phone number or business name for him.
regards neale
neale
