Author Topic: S6 gearbox  (Read 1734 times)
Offline Phils
S6 gearbox
« on: 23 Nov 2015 at 08:38 »
Hi all!
I have some questions about Douglas S6 gearbox.
I have troubles with 1st gear : it engages, but if I go forward 5 meters it stops, as if the cycle went back  at a standstill. I already did adjustments  but nothing of what I tried worked. Do I have to take the gearbox apart? Would you do it?
One other question : how much oil do we have to put in the gearbox? My Douglas is an S6 of 1933, and I found no information about it.
Any info on gearbox will be very welcome!
Thank you very much!
Phil
Offline Bert
Re: S6 gearbox
« Reply #1 on: 23 Nov 2015 at 20:53 »
We probably need more information.  Does the bike slip into neutral or does it lock up the drive train.
A consideration on dismantling it would be whether parts are available.
 I haven't stripped a Douglas gearbox but from what I have read on this forum, the box has grease, not oil. If you search the forum you will see that some recommend a semi-fluid grease.
Bert
