Author Topic: douglas heat shields  (Read 5905 times)
Offline trevorp
« on: 06 Jun 2005 at 06:37 »
i am trying to work out what douglas these heat sheilds are off
they are abot 8 inches long are double skinned and have the word douglas cut out of them with a black background the have brass dome nuts holding then together could they be pillion shields off some model
photo submitted
Offline alwyn
  • 1928 - 2009
  • Co-Founder
Heat-shields
« Reply #1 on: 08 Jun 2005 at 08:37 »
Hi Trevor,
I have looked through a few books looking for shields of the type you have. This is a scan of a shield fitted to a 1948 MkIII Sports - it appears plain without lettering.
and here is another fitted to a 1951 350cc Competition model - it has slots similar to those Doug mentioned HERE
I could not find any similar to those you have and as Doug suggests yours may be an 'aftermarket item'.
I suggest too that if Douglas had made them as an OEM item they would most likely have adopted a font the same as was indented to rocker covers c 1948 and also adopted for signwriting the name on petrol tanks. Further, I believe it would also have had the customary full-stop following the name which is so often conspicuous only by its absence in repaints and restorations seen today.
Alwyn
Site Mod
Offline trevorp
shields
« Reply #2 on: 09 Jun 2005 at 10:29 »
the only thing i can think of is after market for the pillion rider on a sports and i think we need to have a topic about the dot after douglas or is this a confirmed fact
Trevor
Offline trevorp
heat shields
« Reply #3 on: 04 Aug 2005 at 11:45 »
finally found out these heat sheilds fit mark 5 with the low exhausts
the sheild is just to protect your foot if it slips on to the pipe
« Reply #4 on: 05 Aug 2005 at 01:55 »
The 'dot' debate was discussed in this topic:
https://www.douglasmotorcycles.net/index.php?topic=603.0
