Author Topic: 600 1937 aero centre stand  (Read 2733 times)
Offline polly
« on: 03 Sep 2015 at 13:53 »
can anyone help? my centre stand and footrests are a bodge up and seem to be badly thought out! can I ask for a picture of these parts or a sketch showing what's missing and how it should be? thank you! David
Re: 600 1937 aero centre stand
« Reply #1 on: 04 Sep 2015 at 01:03 »
David,
See this post regarding the d-tubing. the stand in red primer is the one from my '36 Aero 600.
https://www.douglasmotorcycles.net/index.php?topic=3624.msg13120#msg13120
I have a drawing for the S6 stand, and can probably adjust it for the Aero dimensions.
Can probably do something about photos of the foot rest stand-offs tomorrow.
Offline polly
« Reply #2 on: 04 Sep 2015 at 06:10 »
many thanks Doug, the main feet seem ok and resemble your pics, how does the stand oscillate , what should be the stop pins and what do the fulcrum sleeves that the brake pedal and footrest look like ?? regards david
« Reply #3 on: 04 Sep 2015 at 13:17 »
David,
Here are some pictures of the footrest extensions/center stand trunions. Somewhere around here I have drawings for the trunions, as these need renewing (as can be seen).
The flats on the trunions engage with the vertical slot of the frame lug. The lug projection at the 2-o'clock position acts as the center stand stop.
[Update image https links. -Doug 30Jan20]
« Last Edit: 30 Jan 2020 at 05:56 by Doug »
Offline polly
« Reply #4 on: 04 Sep 2015 at 18:28 »
many thanks Doug, the pics show exactly what's wrong with mine! the serrated ends have been cut off where the footrest marry up to !! regards David
Offline Jonathan
« Reply #5 on: 13 Jun 2020 at 22:45 »
Hi Doug,
Did you ever find the drawings of the footrest extensions/stand trunnions?
After ten years, I have got back into the S6 project. (Had a little health issue, so now retired and playing in the shed)
Even a sketch with measurements would be fine.
Jonathan
Jonathan H.
« Reply #6 on: 14 Jun 2020 at 00:45 »
Jonathan,
Actually I forgot I was supposed to be looking! The drawings were in the S6 folder, as those Aero part numbers date back to that time. Below each image is a link to a PDF version of the drawing that is a higher resolution.
PDF version
PDF version
PDF version
[Minor corrections to drawing 11427.  14Jun20.  -Doug]
[Minor corrections to drawing 11420, 11421.  08Aug20.  -Doug]
« Last Edit: 09 Aug 2020 at 20:47 by Doug »
Offline Hamwic
« Reply #7 on: 09 Nov 2020 at 16:37 »
Hi Doug,
 I have a further question to the above if I may? I have to make all these parts, but what actually holds the stand in the Up position please, i.e. is it a spring or some kind of clip, and if so, where does it live and how does it work?
Many thanks in advance,
« Reply #8 on: 09 Nov 2020 at 18:28 »
A a hairpin spring slips over the hub of the brake pedal; one leg loops around the brake pedal and the other the eyelet of the center stand. It servs as both the centerstand spring and the brake return spring. Some duplex frame models where the center stand and foot rest did not share a common lug had the spring loop over the engine frame tube for an anchorage. The LDMCC prewar spares have carried these center stand springs in the past, but I am not sure which type (large or small loop for the anchorage) that they carried. The one shown is the actual spring from my 1936 Aero 600. There is not clip to hold the center stand in the up position.
Offline Hamwic
« Reply #9 on: 10 Nov 2020 at 09:05 »
Hi Doug,
Thanks for the picture - it's going to be fun replicating that, my success with springs is about 50/50!
Cheers for now
Offline Red
« Reply #10 on: 10 Nov 2020 at 09:19 »
Hi Doug
I don't know where abouts you are in Hampshire, but I live near to Basingstoke - my address is in the club magazine. I have a 1937 Aero 600 and if you ever want to look at any aspect of the bike your are welcome to come and have a look.
Roy
Offline Hamwic
« Reply #11 on: 12 Nov 2020 at 09:38 »
Thank you Roy, that is a very kind offer that I may well take you up on, and that's a fine looking machine. I'm near Southampton, so not a million miles away.
Cheers for now
Offline Red
« Reply #12 on: 12 Nov 2020 at 11:26 »
Hi Doug
Look forward to it. My address is under the club secretary section on page 2 of the Conrod and my phone number is on page 18 - Where Members Meet - Surrey/Hants section.
Roy
