Author Topic: 1928 Douglas EW carb heat pipe  (Read 3856 times)
Offline patrickhowell
« on: 11 Jul 2015 at 15:00 »
Can anyone post  pictures of an original carb heat pipe for the above, with dimensions, please? Mine is missing, and my toolmaker friend needs these . Thanks
Offline tck
    • old racer
Re: 1928 Douglas EW carb heat pipe
« Reply #1 on: 12 Jul 2015 at 18:29 »
You mean the one that is easily made from a small exhaust pipe?
« Reply #2 on: 13 Jul 2015 at 09:42 »
The pipe which goes from the carb to just above the rear cylinder.
Offline tck
    • old racer
« Reply #3 on: 14 Jul 2015 at 08:57 »
Thats it I think I used a length of tiger cub exhaust pipe with a cast clip
Offline tck
    • old racer
« Reply #4 on: 14 Jul 2015 at 09:00 »
Offline DSIM
« Reply #5 on: 14 Jul 2015 at 20:32 »
Can be formed using a plumbers bending spring out of a piece of 22mm copper pipe which you can anneal and flare at the end. I made mine that way. A spring will cost you about 4 and 2m of copper pipe about 7 assuming you cannot find an off cut.
Offline Boxer
« Reply #6 on: 15 Jul 2015 at 11:22 »
Patrick,
here 2 pictures showing the pipe.
Hope it  help, otherwise can make some  photos of mine.
Greetings Rudolf
Offline polly
« Reply #7 on: 27 Oct 2015 at 14:52 »
does any one know where to get the collar that screws the air intake pipe to the carb from please? david
