Hi all, just coming up to 500 miles since rebuild, and as i was pulling in to garage engine was knocking and running a bit poo so I checked plugs valves,points, timing cover off all looked good to, I have had a lot of an oil coming out from all around mag since I put on a sidestand??? So took off to find it won't turn smooth if at all, it wasn't like it when I put back on,also I tested lights on way home for first time ? I gave it a quick strip down for the first time, i can not see any problems. Top part is good took off ,points all good, lots of black oil or grease in magnetic part and shaft but little bearings look OK, gave quick clean slide back in but still doesn't turn nicely,, what is wrong?? As was hoping to get to stow on da wold, and show off the new omega piston set,many thanks graham
