Author Topic: making rubber parts at home .  (Read 2292 times)
Offline carl denton
« on: 28 Jun 2015 at 11:06 »
hello
dose any one have a idea as to who you can get a kit from that I can use to make rubber parts for my bikes ?
carl .
Offline Dirt Track
Re: making rubber parts at home .
« Reply #1 on: 29 Jun 2015 at 01:22 »
G'day Carl.
I get resin products from my local fibreglass supply shop here in Hobart, it is available in different hardness's. I guess you want to make foot boards and the like.
I have attached a photo of some JAP footboards I made recently.
Howard.
« Reply #2 on: 29 Jun 2015 at 12:51 »
Carl,
You will want to do a bit of research first, as there are at least two basic materials you could use to cast your own rubber-like parts. One is a urethane and the other is a silicone; neither are an genuine vulcanized rubber.
The urethane has the advantage in that the resins are relatively cheap and setup quickly (sometimes too quickly!) But it does tend to tear easy, hence the cheap foot rest rubbers one buys that split after pressing them on over the foot pegs. The silicon (often called Room Temperature Vulcanizing silicon rubber, RTV) is much more durable, but the resins are considerably more expensive than the urethane.
Studying the larger supplier's websites for FAQ and Technical Guides (such as http://www.smooth-on.com/ ) will get you started on how to tackle your rubber casting project. The main issues you will encounter are bubbles, cure inhibition, and more bubbles!
