Author Topic: Torsion Bar T35  (Read 2184 times)
Offline douglas1947
Torsion Bar T35
« on: 28 May 2015 at 19:34 »
has anyone experience in converting the bushes in the conecting links to rubber bushes?
Re: Torsion Bar T35
« Reply #1 on: 28 May 2015 at 20:36 »
Hi Michael,
                 I believe the bushes that were used were originally from the engine stabiliser on a Mk2/Mk10 Jaguar car.
Offline douglas1947
Re: Torsion Bar T35
« Reply #2 on: 29 May 2015 at 11:48 »
Yes, they have part no. C 10940.
But how are the "socket balls" ( item 42/ Plate 20) fixed in the links?
What is the way to get them out?
Re: Torsion Bar T35
« Reply #3 on: 29 May 2015 at 15:03 »
With the pivot bolts removed, the balls can be turned on their sides and removed through the slot on one side of the link.
Offline douglas1947
Re: Torsion Bar T35
« Reply #4 on: 01 Jun 2015 at 15:46 »
Eddie,
thanks for your tip. Itīs very easy  -  but you have to know!!!
What is the way to grind out the holes in the connecting links?
Offline douglas1947
Re: Torsion Bar T35
« Reply #5 on: 22 Jun 2015 at 18:07 »
How much clearence is normal for the socket balls in the connecting links?
I found out on the second bike (MK5) is also around 0.5mm clearence.
Is that normal or too much?
I think I have to destroy the housing in the links for change to rubber bushes. And that is non reversible!
