Author Topic: DYNAMO BTH "PANCAKE"  (Read 2033 times)
Offline ANTOINE
« on: 26 Mar 2015 at 17:40 »
Hello ,
 I have a 600 AERO DOUGLAS and some problems with the dynamo.There is 6 volts and more but 1 ampère only , not enough to charge the battery.
Do you know this problem ( remagnetising the magnet  ) ???. Do you know this problem ? do you know an adress to make correctly the work ?
I am in France , and I don't find a supplier who know very well this model ?
Thank you for your help . best regards.
Re: DYNAMO BTH "PANCAKE"
« Reply #1 on: 26 Mar 2015 at 22:06 »
Antoine,
Review this post on the BTH PA series dyno:
https://www.douglasmotorcycles.net/index.php?topic=2461.msg8898#msg8898
Output is very low, even under optimal conditions. 20W maximum when they were new, if that. I do not know of anyone rebuilding or servicing these dynamos as a business. Several folk have hidden small alternators inside a replica BTH housing, and a post on that subject can be found here:
https://www.douglasmotorcycles.net/index.php?topic=2386.msg8609#msg8609
