Author Topic: 2 3/4 hp, how much gear box grease?  (Read 3973 times)
Offline th63ko
« on: 01 Mar 2015 at 11:33 »
hello,
request advice on the following, please:
from a reprint manual for 2 3/4 hp models, years 1912-1914, i have read that 2-speed gearbox shall be filled with grease.
older articles in this forum indicate that semi-fluid grease should be used.
ok, i have this. consistency is similar to honey and meets the descriptions.
but, how much is a suitable filling? topped up or less amount?
thank you for proper advice
holger, germany
Re: 2 3/4 hp, how much gear box grease?
« Reply #1 on: 01 Mar 2015 at 15:08 »
You do not want to top up the box completely, it will just rapidly leak out. You need a minimum of lubricant in the gearbox to submerge the lower portion of the gears so that they pick up the oil/grease and distribute it around the inside of the gearbox. Ideally you want a little more than this, as there are no seals in the gearbox. It leaks out and you do not want to run short. Also a small, but steady intentional leakage of lubricant from the gearbox via the shafts help prevent the ingress of dirt and water. Better some lubricat getting out, than contaminants getting in.
Offline Black Sheep
« Reply #2 on: 01 Mar 2015 at 17:41 »
When I recommissioned mine, with a remarkable lack of subtlety I filled my gearbox up with semi-fluid grease using a 60ml syringe then set out for a long ride. The surplus worked its way out past the mainshaft and lubricated the chain. Thereafter I just top up the box with 30 mls of grease once in a while. A bit hit and miss but it works. If you adopt this approach, best not to park on a newly laid drive after that first ride. However, the dripped grease will, after a year or two, just about disappear.
Offline shuswapkev
« Reply #3 on: 02 Mar 2015 at 10:46 »
not intending to hijack a thread...
 but I take oil spots off with laundry detergent...made into a paste...leave on for a day or three...
works for me
« Reply #4 on: 02 Mar 2015 at 21:53 »
Be careful using grease in gearboxes. Depending on grade and properties, you might end up with the the gears spinning dry in cavities in your grease-filled box. Penrite used to make a semi-fluid grease for gearboxes (which I didn't like too much as it tended to foam and escape from everywhere, including the top), but lately I've been using a very heavy gear oil (150 I think) made specially for vintage gearboxes. It works well for me.
My garage floor is well beyond cleaning...
Offline Black Sheep
« Reply #5 on: 03 Mar 2015 at 16:34 »
Morris oils make a good semi-fluid grease. They do sell mail order, so possibly available in Germany. The Douglas spots in my drive have finally disappeared - the garage floor is beyond hope but that's the Norton chaincase to blame. Must get round to sealing it yet again. But not before the Douglas gearbox is sorted.
