Author Topic: parts interchange between years  (Read 1832 times)
Offline steveale
« on: 21 Feb 2015 at 03:36 »
Can '16 cylinder barrels be used on a '13 motor (2 3/4)?  Is there any way to identify/distinguish loose parts such as springs, valves, timing gears that interoperate on these early 350 engines?
Looking at only workable spares for an endurance run, don't have to be model/year accurate.
Re: parts interchange between years
« Reply #1 on: 23 Feb 2015 at 20:15 »
Hi Steve,
I'm not expert on the veteran 2 3/4, but if I get it wrong someone will say!
Yes the cylinders will interchange. It's common to see veteran engines like the 1913 with 1920s cylinders. The early cylinders have very few fins, particularly around the inlet ports. Also the early ones have a priming cup on top (as it sits in the frame) of each cylinder, to add a bit of paraffin (kerosene) or petrol to free up gummy oil before starting in the morning.
The timing gears on the early motors are narrower than those in the later models.
