Author Topic: t35 advice needed  (Read 2165 times)
Offline Graham prichard
t35 advice needed
« on: 14 Dec 2014 at 12:29 »
hi all any ideas on what plate is for?? In timing case and markings been put on clutch plate?not read anything about marks in manual??
Re: t35 advice needed
« Reply #1 on: 14 Dec 2014 at 17:24 »
Hi Graham,
                  The markings on the clutch are obviously a previous owners attempt at accurately setting the valve and ignition timing. The large markings are at 10 degree intervals, with smaller markings at 2 degree intervals.
 Regarding the plate in the timing chest - the only purpose I can think of, is that it may have been fitted as a baffle to deflect oil spray if an auxiliary breather had been fitted to the oil filler plug.
« Reply #2 on: 14 Dec 2014 at 18:27 »
Hi Eddie
              Yes oil filler has been well modified with non return valve (I can blow out but not in)pipe goes to chain cover was very well done.
 Yes I thought they were timing marks but never could get my head around using them.
Also Eddie could you recommend someone to rebuild a crank and rebore as I dont want to take to any body I live  in Essex??
