Yesterday at 09:23:12
Magneto BTH
Started by Michel H, 19 Oct 2014 at 17:51
Michel H
Hello,
On my EW350 the magneto is the right BTH M2w2. Do you know the signification the code 6E 14318 and the number 606991. Also the mention Eclipse N, what all that means ?
Thank you.
Michel
eddie
Hello Michel,
                   I can't help with the code but I would think that 606991 is the serial number of the magneto. Is the 'Eclipse N' on one end of the magnet? - if so, then it is the manufacturer's stamp. Eclipse were a well known British manufacturer of magnets - the 'N' denotes which side of the magnet is the 'North Pole'.
