Author Topic: Bantam Frame alignment  (Read 1303 times)
Offline JonathanJoy
« on: 16 Oct 2014 at 19:24 »
Hi
I'm just assembling my Douglas Bantam frame. The rear is  out of  alignment by quite a few degrees in the vertical plane.  Since its a bolted together frame with rubber shock absorbers between the joints I suppose its to be expected.
Has anyone had experience of assembling a Bantam frame or know of a technique to true the frame, I'm a little worried about using a bar to correct the alignment  :?
Any advice would be much appreciated.
Jonathan
