Author Topic: T6 Ignition timing  (Read 1987 times)
Offline Jeffrey Rook
T6 Ignition timing
« on: 14 Oct 2014 at 12:30 »
With modern fuels etc what would be a good starting point before TDC for T6 ignition timing  thanks Jeff
Re: T6 Ignition timing
« Reply #1 on: 15 Oct 2014 at 06:33 »
Hi Jeff,
           With a softly tuned side valve engine like the T6, I wouldn't have thought there was any need to adjust the timing. In any case, the T6 is fitted with a manual advance/retard, so set it up to the standard figure and then play with the advance/retard until you find the spot at which it runs sweetest.
« Reply #2 on: 21 Oct 2014 at 10:32 »
Hi Thanks Eddie jeff
