New KLG spark plug
Started by RockDr., 01 Sep 2014 at 12:40
RockDr.
Question to all 2 3/4HP TS runners out there .....  has anyone had any experience with the new long reach KLG ML50 spark plug. Recommendations ? comments?
Best Regards
Chris
carcrank
Although I have not tried the ML50 on my TS I have used one in my single cylinder veteran car and just did 4000kms over the last month without removing it.
Mark
Ian
Interesting - anyone know what heat range they compare to in NGK ? I have been using the NGK AB6 but would prefer a long reach plug for many of my bikes
RockDr.
Cheers !
I know there has been the discussion of using the 14mm plugs with reducers fitted however  I just thought maybe someone may have tried these.
It may be the case where I just simply try and then let you guys know.....
Ian
We have used the reducers with NGK ES plugs - the one advantage of that is the TS usually seem to run differently front and back cylinders so you can put different heat ranges in. We are back to the 18mm plugs now though
cardan
I've run the ML50 plugs in various machines which will take a 3/4" reach plug. In the 1914 Radco two stroke the improvement in performance over a 1/2" reach Champion D16 was very noticeable. Make sure to measure before using a long reach plug!
RockDr.
Hi Ian, info that I found for the KLG ML50
"Long reach 18mm spark plugs
Insulator made by Alumina (Al2O3)
Heat range adjusted to 190 +/- 10% imeps.
(171 to 209)
Spark plugs would be Ni-Cr quality
Additional Information
SKU    1522
Manufacturer    KLG
Part Number    ML50
Diameter    18mm
Reach    19mm (3/4")
Hex Size    25.4mm (1")
Seal Type    Gasket Seat
Resistor    No
Terminal Type    M4 Thread
Electrode Material    Standard Nickel
Projection Type    Non Projected
Tip Configuration    Single Electrod
Ian
Thanks for that info. I sent a message to Greens Spark Plugs who make them - they said it covers the same heat range an NGK AB6 covers
