Author Topic: Mark 4 frame number  (Read 1910 times)
Mark 4 frame number
« on: 11 Aug 2014 at 00:39 »
I have purchased a Mark 4 which has no frame number. To register it here I need to apply one. I know that there are quite a few replacement frames out there with no numbers - is there a prefix that should be used to identify it as such ? It would appear that as is the case with many old bikes this one was separated from its frame at some stage as the LDMCC machine register lists one which has a frame number the same as my engine number (but with an earlier engine fitted).
Re: Mark 4 frame number
« Reply #1 on: 14 Aug 2014 at 00:57 »
Any advice from others who have had to specify a frame number in these circumstances ?
Offline frankclock
« Reply #2 on: 13 Sep 2014 at 06:38 »
Ian
I have a MK 1V & am willing to give you my frame number details if that is any help to you
FRANK DEAN
SHELLHARBOUR
