timing and magneto gears
Started by kev, 30 Jul 2014 at 11:50
kev
I am parting together a 26 ew...  I have just picked up a magneto...(still works!)  the drive gear...is there any special type??   the person I bought it from said maybe some sort of special centre??
  the tapered shaft is cut for a key??  does my mag gear need a keyway...if so how would you set the timing...or is just the universal 180 magneto?
basically my question...what does the mag drive gear look like??
the mag does throw a pair of good sparks...but I am sure it will need a rewind
