Author Topic: 3/4" drive belt  (Read 2883 times)
Offline Ken Rogers
  • 1926 EW350
3/4" drive belt
« on: 15 Jul 2014 at 17:49 »
Hi can anybody tell me where I can obtain some 3/4" drive belt of any type. regards Ken Rogers
Offline IPalmer
Re: 3/4" drive belt
« Reply #1 on: 15 Jul 2014 at 18:48 »
Hello Ken,
I have just bought some 22mm (close to 7/8inch) type "c" Brammer "v"belt from WWW.stationaryengineparts.com. This fits my 2 3/4 perfectly.
I know they do other sizes. It might be worth a go. Mine arrived today (bought 5 metres of it) and it is good quality and matches my existing belt really well.
If you type in "Brammer" in their search engine it brings up all their belt sizes.
I hope this helps.
Kind regards,
Ian
Offline MRD
Re: 3/4" drive belt
« Reply #2 on: 15 Jul 2014 at 19:45 »
Hi Ken
If its for a Douglas then I believe it should be 7/8" belt.
You can get this and the belt link from the VMCC shop
it an be found at
http://www.vmccshop.net/p/6038/drive-belt-vmcc-limited
Hope this helps
Regards     Martin
Re: 3/4" drive belt
« Reply #3 on: 16 Jul 2014 at 01:09 »
You can get C section belting from any bearing/engineering supplies factor. I have used Opti belts, these come in 1" increments, so you need to have some idea of the length required. The advantage of this type of belt is that they never stretch - unlike Brammer belt, which never stops stretching!
Cheers, Graeme
Offline Ken Rogers
  • 1926 EW350
Re: 3/4" drive belt
« Reply #4 on: 16 Jul 2014 at 18:14 »
Hi all thanks for the replies ,the belt is for my 1914 New Hudson 211cc and needs to be 3/4" I have tried "c" section belt but it is too wide and rides high up out of the pulleys on the other hand the "b" section belt bottoms out.I bought some 3/4" brammer belt from America but when it came it was "b" section .Many thanks Ken
Offline Ken Rogers
  • 1926 EW350
Re: 3/4" drive belt
« Reply #5 on: 23 Jul 2014 at 08:47 »
Hi all Veteran Triumph Spares has just got 3/4" brammer belt back in stock if anybody else is looking for some,they also keep other sizes as well. www.veterantriumph.co.uk       regards Ken
