Author Topic: EW 350 engine and CW or SW engine  (Read 2468 times)
Offline Andreas
« on: 12 Mar 2014 at 08:55 »
Dear all,
As there is the possibility to get some parts for my Douglas projects I´m asking for your help to identify the parts. Thanks in advance.
Andreas
« Last Edit: 13 May 2014 at 07:54 by Dave »
Offline Andreas
Re: EW 350 engine and CW or SW engine
« Reply #1 on: 13 Mar 2014 at 12:30 »
Whitout knowing the frame and engine numbers, is this a CW or a SW 1924 (chain or belt drive)? Can anyone let me know an indication price for what we can see on the two pictures: Any help is appreciated.
Andreas
« Last Edit: 13 May 2014 at 07:55 by Dave »
« Reply #2 on: 13 Mar 2014 at 17:24 »
Hi Andreas
One of the main differences between the CW and the other models is the number of gears. The CW is three speed and the SW and TS have two speeds. So an easy means of identification is to look at the gear gate on top of the frame which looks to be two speed. However, the SW also has a flywheel clutch and uses a 1/2 x 3/16 chain. From the view of the flywheel which is not a flywheel clutch and the size of the chain (appears to be 5/8" x 1/4") it looks as though you have a TS frame and engine. Chris.
