Author Topic: Help for a Douglas fan in Argentina  (Read 3828 times)
Offline raul
« on: 11 Jan 2014 at 23:04 »
Hello there.!, I'm Raul from Argentina and I'm close to buy a Douglas motorcycle, but I need some help to understand model, where are the engine and frame numbers an any other tips to identify the motorcycle. I would really appreciate any help. I'm attaching a photo.... thanks in advance..
Raúl
Re: Help for a Douglas fan in Argentina
« Reply #1 on: 12 Jan 2014 at 02:03 »
Hello Raul,
It looks to be a Mark 3 Sports model. Frame and engine numbers can be found as per the marked up image below.
It has the early sub-frame mounting (A) indicating a Mark 3 or earlier frame. The clips at (B) are for the panier toolboxes as fitted to the Mark 3 Sports model. The appropriate frame codes and numeric ranges can be found via the link in this post:
https://www.douglasmotorcycles.net/index.php?topic=490.0
For example a Mark 3 Sports should be stamped on the engine and frame from T35/S/4001/S to  T35/S/4001/S6589/S. The engine and frame numbers would have matched upon leaving the factory.
Offline javito86
« Reply #2 on: 14 Jan 2014 at 01:30 »
raul buenos dias!
Soy Javier de Argentina, de Cordoba!
tengo una Douglas hace casi 2 años y la estoy restaurando, te paso mi mail asi nos comunicamos!
Saludos!
jiso86@gmail.com
« Reply #3 on: 14 Jan 2014 at 01:39 »
Raul,
Pictures of a Mark 3 Sports restored to original condition (except for finned faux exhaust nuts) can be found in this post:
https://www.douglasmotorcycles.net/index.php?topic=1995.0
Offline tck
    • old racer
« Reply #4 on: 14 Jan 2014 at 18:25 »
Mk 3 indeed but is that an induction tube I can see?
Has it been fitted with a manifold to run from 1 carburettor like the dragonfly? I did not think its for an air filter as the bore is small and it looks like a flange with vertical holes to match the cylinder head 'carb' fitting
Offline raul
« Reply #5 on: 14 Jan 2014 at 23:28 »
Doug, thanks a lot for your help, because of you I was able to check frame and motor serial numbers!! Right now I'm listing spare parts such as piston rings, gaskets, seals, carburetors, etc to buy up there in a dealer, if you have any suggestions will be welcome..
Again thks a lot!!!
Best regards!
Raul
Offline raul
« Reply #6 on: 14 Jan 2014 at 23:35 »
Tck, excelent catch!! Is a manifold to feed both cylinders with one non original carburator. It is Mk III the serial numbers confirm that.
Offline tck
    • old racer
« Reply #7 on: 15 Jan 2014 at 08:11 »
that has got to be a real power sapper. two separate carburettors would be first on my list I actually wince when I see the bend in the pipe just before the cylinder head
