Identify a Douglas gear box clamp - 3 1/2 or 4 horse maybe?
Started by cardan, 05 Jan 2014 at 23:38
cardan
I can rule out RA, but perhaps 3 1/2 or 4 h.p.? Can anyone identify it? The two sides are slightly different, but I'm pretty sure it's a clamp to hold the gearbox to the back/bottom of a Douglas crank case. Quite an unusual part!
Leon,
It sure looks like 4hp. The spares list shows a triangular plate, but pictures of actual machines seem to have this type.
cardan
ID in 10 minutes - not a bad service on this website! Thanks Doug. Drop me a PM or email if you NEED this clamp.
graeme
wilf
