Author Topic: 1926 EW 350. Rear brake pedal wanted.  (Read 2930 times)
Offline nitsua
« on: 27 Nov 2013 at 14:30 »
Wanted, rear brake pedal to suit a1926 EW 350.
Offline ste
Offline oily bloke
Re: 1926 EW 350. Rear brake pedal wanted.
« Reply #2 on: 30 Nov 2013 at 07:28 »
Unless the photo is reversed thats a righthand pedal.
Offline Jim
« Reply #3 on: 30 Nov 2013 at 09:28 »
Hello, that isn`t a 350 EW brake pedal, I don`t know what it fits, Jim
Offline oily bloke
« Reply #4 on: 30 Nov 2013 at 09:41 »
It might make the basis of a pedal you can alter to suit. A bit of heat and modification it could work. There is a factory drawing of the pedal and I made one from scratch as I looked for ages  and could not find one. The EBay one is nearly right. Needs the bend reversing and the boss modifying. The striations on the foot plate are right so it may be a Douglas part but I know not what.
Offline oil baron
« Reply #5 on: 30 Nov 2013 at 18:35 »
Hi
I suspect this is a foot clutch pedal for an early 4hp machine
SteveL
Steve L
