Author Topic: 1927 EW 350cc Gearbox  (Read 2710 times)
Offline tritonyabby
« on: 27 Nov 2013 at 11:55 »
Hi all. New to the forum and hoping you can help. As I'm not a douglas man, sorry all, but need some input for how much I would sell a 1927 EW 350cc gearbox for(RG\B15047). I have a possible buyer but no idea what its worth. Its not seized, has selector and kick starter,  possibly missing spring? see last photo, and has sprockets attached as can be seen in photos, and is in relatively good condition.
Would really appreciate your help.
« Last Edit: 21 Aug 2014 at 02:16 by Dave »
Offline Alan Cun
Re: 1927 EW 350cc Gearbox
« Reply #1 on: 28 Nov 2013 at 08:42 »
The outer sprocket is a foreign add on however mostly the kickstart is missing from these boxes and the big chain wheel is normally worn out. The return spring can easily be made from a mower recoil starter spring. What you have should a least be worth around A$ 200. Maybe more ????????????
regards Alan
Offline tritonyabby
« Reply #2 on: 28 Nov 2013 at 09:28 »
Thanks for that Alan. It's sat in the shed here for about 23yrs and an old blokes shed for a lot of years before that. Haven't cracked it open but it can actually still select a gear.
Appreciate your comment. Any other input welcome
Offline shuswapkev
« Reply #3 on: 12 Mar 2014 at 11:54 »
yabby
 I am looking for a 27 ew gearbox...let me know if available...and anything else
« Reply #4 on: 12 Mar 2014 at 14:56 »
It is a 1925-26 gearbox. In 1927 the mounting of the gearbox changed to clamp around the frame tubes. The earlier gearbox sat on a platform, such as the one you show.
