1924 2 3/4hp - How many rubber studs to each footboard?
Started by spency777, 24 Jul 2013 at 14:52
spency777
Hi again,
Does anyone have a definitive answer to how many rubber studs should be put into an aluminium cast footboard? Also should they be domed or flat head (the LMDCC sell both). The pictures I've seen on the internet seem to vary.
I'll be buying the "official" sized ones from the LDMCC.
Thanks again
Richard
Chris
Hi Richard
    Original specification for 1924 models had footpegs for the TS model and cast alloy footboards for the SW and CW models. Douglas would supply what buyers wanted and it appeared that In Australia they favoured footboards for the TS models as well. If the correct alloy footboards are fitted then they should have 26 rubber pads on each board i.e. 52 in total. Also they should be the domed variety up to the 1926 CW. The EW of 1926/7 has a different cast alloy footboard with only 13 pads each side which should be the flat variety. Hope this helps. Chris.
spency777
Wow, that was a fast reply, thanks very much!
I even bought Jeff Clews book to try to see a photo but that didn't work either.
So 52 round top rubber studs it is, pity they are £1.50 each though!
All the best
Richard
