Author Topic: Domed pistons for early T35 wanted  (Read 2058 times)
Offline bkinghor
« on: 20 Jun 2013 at 11:18 »
My recently acquired and well restored T35/S/269 was set up with 3 thou clearance, and it tightened up a couple of times.  300 miles only.  One piston had a couple of stuck rings, both pistons are scored somewhat.  I think my pistons are just in a serviceable state, after TLC, but I'd prefer a new or very good pair, ideally with rings and pins.  Size is STD, but anything bigger could be interesting.
They are domed 'generator' pistons, as in the attached photo.
Many thanks!  Brian
Offline monk
Re: Domed pistons for early T35 wanted
« Reply #1 on: 05 Oct 2013 at 14:29 »
Are you still looking for pistons I have a pair but no rings, I think they came from a T35 Generator engine, but I have used a set in my T35Mk1 with no problems, there is a light mark on the bottom of one skirt, I also have rocker gear, two barrels ,and rocker covers. my email address is <removed>, They are STD. Peter
[Email address removed. Use email or PM links to the left. -Doug, Site Moderator, 05Oct13]
« Last Edit: 05 Oct 2013 at 22:28 by Doug »
