2024-06-08, 19:30:04
For Sale
2024-06-07, 03:13:36
2024-06-03, 09:23:05
For Sale
2024-06-02, 09:34:05
Parts avalable
2024-06-01, 19:33:27
2024-05-28, 01:09:46
Welcome to the new site!
Mk clutch thrust disc wear
Started by richson, 15 Jun 2013 at 21:39
richson
Hi, attached is photo of the clutch outer plate on an engine i'm rebuilding. Showing a lot of wear on the thrust disc. Is this usual? What is the cause?
cheers, Neil
eddie
Neil,
        The ring of wear shown in the photo is caused by the pressed steel retaining ring on the clutch release standing proud of the thrust face and wearing into the tufnol disc. This may be the result of either the retaining ring being distorted or the thrust bearing itself being worn enough to let the thrust ring sit lower than the surrounding body. Providing you repair or replace the clutch release, this outer plate should be OK to re-use - that is, assuming the rivets are still tight. The clutch thrust actually sits inboard of the area of wear.
NeilR
Thanks Eddie,
Unfortunately the retaining ring is rusted thru, and last time I asked there were none in club spares. I'll ask again! Seems a very flimsy item.
Cheers, Neil
chippy
Hi Neil, Are you going to the rally at Stow at the weekend, if so I have a used one you could look at. Regards Eric (Regalia sec).
NeilR
Hi Chippy, thanks for the offer but I don't have a road-going Douglas at the moment so not at the rally. Comp is dead with broken frame and the Mk is in about as many parts as there are.
cheers,
neil
