Author Topic: EW350 crankshaft nut locking washers  (Read 2293 times)
Offline oily bloke
« on: 04 Mar 2013 at 10:01 »
Hi all,
I am looking for a pair of tab/locking washers for the nuts on the crankshaft of my EW. Mine were missing and I would assume they are quite important!
The LDMCC spares scheme do not appear to have any.
Can anyone help?
Is there an alternative?
Andy
Re: EW350 crankshaft nut locking washers
« Reply #1 on: 04 Mar 2013 at 14:27 »
Hi Andrew
    I believe that the LDMCC pre-war Spares does hold these as well as small tab washers for the inside of the timing chest. They are listed only as tab washers various I believe in the Spares list. I suggest that when requesting them that you specify the diameter of the bolt/nut as there are several different big-end tab washers and Douglas changed the diameter of the bolts/nuts from model to model. Chris.
Offline coles1933
« Reply #2 on: 15 Mar 2013 at 17:58 »
I needed 2 of these washer to complete a crank I have been working on and they came from the club spares man in under a week, very good service coles1933
