Author Topic: Douglas Dragonfly 1956 Rear Wheel Offset British Hub Brake  (Read 3609 times)
Offline BrmBrm
Anybody know what this should be?
I mean the dimension from edge of wheel rim to outer edge of brake drum
Offline BrmBrm
Re: Douglas Dragonfly 1956 Rear Wheel Offset British Hub Brake
« Reply #1 on: 11 Feb 2013 at 13:18 »
Just to let the readers of this post know -
I have set rear wheel spacers to suit the fit of the brake arm shoulder screw, and align the sprockets. I've adjusted the spokes so that the wheel is central in the swinging arm and in line with the front wheel.
Offline NeilR
« Reply #2 on: 12 Feb 2013 at 12:28 »
Hi BrmBrm,
If you're a LDMCC member, you could write to Frank Dolman who is Tech contact. He will reply with the information you need. I know this works!
Cheers,
Neil
Offline chippy
« Reply #3 on: 13 Feb 2013 at 18:37 »
Hi Brm, My Rear wheel was assembled with a 15/8" offset twixt rim and brake drum. I took that measurement from an old assembled wheel so I guess it's right. anyway It worked for my bike ! Sorry I did'nt answer your request earlier.  Eric
Offline BrmBrm
« Reply #4 on: 14 Feb 2013 at 15:17 »
Hi Chippy, many thanks for your reply.
Is the 1-5/8" dimension from the edge of the wheel rim to the outer (open) edge of the brake drum?
Again, many thanks for taking the trouble to reply.
Offline chippy
« Reply #5 on: 14 Feb 2013 at 17:56 »
Hi Brm, Yes, Wheel less the spindle laid on the bench drum down , then measure between bench and rim. should measure 15/8. just for information the front wheel measured in the same way should be 3/8" hope this is helpful. regards Eric.
Offline BrmBrm
« Reply #6 on: 15 Feb 2013 at 08:24 »
Many, many thanks Chippy.
