Author Topic: Mk Gearbox spacer dimensions  (Read 3118 times)
Offline NeilR
« on: 26 Jan 2013 at 18:00 »
Hi, can anyone please tell me the lengths of the gearbox spacers (items 11 & 12 plate 20) nos 29978 & 33763.  Thanks, Neil
Offline Vermont-Ian
Re: Mk Gearbox spacer dimensions
« Reply #1 on: 02 Mar 2013 at 01:50 »
Mine have lengths 2..25" and 0.8" as best I can measure with a vernier caliper without taking the bike apart.
But I have to slide in a couple of washers to get a snug fit before tightening the footrests, so mine may worn be a bit short.
Measure the gap in the frame, and the width of the gearbox to get the total length
Assuming you're making them on a lathe, or cutting from tube, make them a little long to be on the safe side, then trim.
OD is not critical, of course.
Maybe you already have this info - took me a while - it's been cold out there.
Ian Stokes
Richmond, VT, USA
Ian Stokes
Richmond, Vermont, USA
1948 Mk III
1936 Citroen 'Traction' 7C
« Reply #2 on: 02 Mar 2013 at 06:23 »
Neil,
       The Mark series machines had solid spacers which often worked loose ( there is very little 'give' in the frame due to the close proximity of a cross tube). Plus series machines and the Dragonfly had adjustable spacers in the form of a threaded sleeve and a deep nut. It may pay you to make up something similar - at least on one side. The sides of Mark gearboxes are often recessed where the spacers have been able to move.
Offline NeilR
« Reply #3 on: 03 Mar 2013 at 10:32 »
Thanks for the help chaps.
Both of the 'boxes I have are recessed, but only on the kickstart side, I'll fit an adjustable one there.
Cheers,
Neil
Offline coles1933
« Reply #4 on: 15 Mar 2013 at 18:15 »
I have been making the 80/90 adjustable spacers for some 6 years now.The reason for these spacers on these
machines is not only to take up the space between the frame and gearbox but to also get the chain running in
a straight line between the  gearbox and rear sprocket, I can supply anybody who is interested in making these with a drawing and a data sheet showing the required set up method. The system is simple and allows a very accurate alignment to be made. Using these spacers can save you considerable power and help your fuel consumptoin figures  coles1933
