Author Topic: Pump mount  (Read 2147 times)
Offline ste
Pump mount
« on: 08 Dec 2012 at 05:10 »
Where does the pump mount on a TS frome?
I was told that they sit under the bar that supports the tank, but neither of my 2 frames have any lugs for a pump.
Stephen
Offline kmd
Re: Pump mount
« Reply #1 on: 08 Dec 2012 at 18:33 »
Hi Stephen
My brother has a TS and I have a model” V” both have pump mounts  on the side of the
Tube under the fuel tank ( flywheel side), But I also have  got a fuel tank with pump mounts soldered
on the bottom of the tank (flywheel side).
Kevin
Offline ste
Re: Pump mount
« Reply #2 on: 08 Dec 2012 at 21:13 »
Thanks for that. Will have to copy some and get them made.
Stephen
