Author Topic: 2 3/4hp mounting of the tyre pump  (Read 3452 times)
Offline kmd
« on: 05 Nov 2012 at 14:22 »
HI All
Can anyone help? On the 2 3/4hp in what year did Douglas move the
Pump fittings from the frame to the tank or was it done by model.
As I have fitting on the frame (1919/20 and on a tank(unknown).
Kevin
Offline MRD
Re: 2 3/4hp mounting of the tyre pump
« Reply #1 on: 05 Nov 2012 at 16:01 »
Hi Kevin
I've just had a look at my 1924 TS which has its original tank. The pump mounting is on the frame.
Regards      Martin
Offline Black Sheep
« Reply #2 on: 12 Nov 2012 at 12:41 »
On my 1913 Model O, the pump in mounted on the left side of the frame tube which runs under the tank. Hope that helps. Gordon.
Offline kmd
« Reply #3 on: 12 Nov 2012 at 13:25 »
Hi Gordon/Martin
Thanks for the reply
I have looked though a lot of photos and It seem that all 2 3/4's have the fixing on the frame.
Unless the fitting on my tank were put on by a owner in the past, being easy to solder on the tank instead of the frame?
Kevin
Offline magoo39
« Reply #4 on: 27 Dec 2012 at 07:52 »
Hi The pump brackets on my 1911 are on the tank but now i don't know if that is original or not.
I have put them on my new tank as they looked like they were original and i don't have any on the frame
Melvin
« Reply #5 on: 28 Dec 2012 at 09:01 »
Hi Melvin
    It is correct for the pump brackets to be on top of the petrol tank for the 1911 model but all my later 2.3/4hp models from 1916 onwards to 1925 have the brackets on the left hand side of the frame tube beneath the petrol tank.
Chris.
