Author Topic: New TS Pulleys  (Read 5591 times)
Offline ssellar
New TS Pulleys
« on: 01 Nov 2012 at 04:20 »
Hi Guys,
I've finally finished making pulleys to suit my 1924 TS with a two speed gearbox.
They are made from a solid steel billet and some have been nickel plated.
The costs are AU$145 for unplated and AU$190 for polished and plated +GST if applicable and delivery.
If you are interested in purchasing please send me a message or give me a call.
I'm located in Sydney if anyone wants to have a look at them.
Thanks for being patient
Stephen Sellar
0432 881 141
« Last Edit: 24 Dec 2012 at 17:39 by Dave »
Offline chris mac
Re: New TS Pulleys
« Reply #1 on: 01 Nov 2012 at 04:52 »
Stephen
                Can you tell me what effective belt diameter ?  As I understand it the pulley and sprocket should be the same diameter, I'll check the sprocket diameter on my gearbox tomorrow.  My bike is a 1914 with a 1919 engine so who knows whats right !
Best
Chris Mac
Offline ssellar
Re: New TS Pulleys
« Reply #2 on: 01 Nov 2012 at 06:49 »
Chris,
The effective belt diameter is 154mm. To get this figure I placed the belt on the pulley and measured the outside diameter (172mm), I then subtracted the belt thickness and my result is 154, same as my roller pitch diameter of my sprocket. I hope this helps.
Stephen
Offline chris mac
Re: New TS Pulleys
« Reply #3 on: 01 Nov 2012 at 21:19 »
Stephen
                     Sorry, but my sprocket is less than 5" PCD so your pulley would be too big.  What cross section ( number ) belt are you running ?
Best
Chris Mac
Offline Andreas
Re: New TS Pulleys
« Reply #4 on: 24 Mar 2014 at 15:26 »
Hi Stephen,
As I just bought a TS 25 Im interested in your offered pulley. Is it still available? and can you send it to Austria?
Andreas
Offline ssellar
Re: New TS Pulleys
« Reply #5 on: 25 Mar 2014 at 09:57 »
Hi Andreas,
Yes I have a few pulleys left. If you would like to contact me directly at (Stephen@bigjack.net.au) I can tell you the total cost which includes postage.
I have sold quite a few already without any complaints!
Stephen
