Author Topic: EW Valve compressor  (Read 4081 times)
Offline tck
    • old racer
EW Valve compressor
« on: 31 Oct 2012 at 14:23 »
Has anyone a valve compressor tool suitable for an EW?
or perhaps a drawing or sketch of one
I love the way it says its "a job to do by the road side... "
Offline roy
Re: EW Valve compressor
« Reply #1 on: 31 Oct 2012 at 19:45 »
Hi, not sure if the attached is any good but at least you can see how it all goes together.
Roy.
Larger view
« Last Edit: 24 Dec 2012 at 17:45 by Dave »
Offline tck
    • old racer
« Reply #2 on: 01 Nov 2012 at 09:52 »
Thats a good view of the valve chest - not a lot of room
I have seen a few second hand side valve spring compressors for sale but they all seem to be for sv cars (Terrys universal etc)  I dont know if they will fit in the douglas space. and I might buy it and find its no use. I dont mind making one up but I would prefer a drawing or a couple of photos of something that works with a coin or ruler shown to give me scale.
Offline shrinker
    • SmartCarby
« Reply #3 on: 01 Nov 2012 at 11:15 »
I know this is off subject but it appears to me that the angled valve arrangement driven by one common cam lobe makes the valve timing different on the front cylinder compared to the rear. Does anyone know if this was by design to correct an issue or was it just a "that will do" decision?
Bruce Robertson
SmartCarby
« Reply #4 on: 01 Nov 2012 at 12:19 »
Bruce,
          If you look again, you will see that the feet of the followers are also angled so that the working faces are vertical - giving the same timing and lift on both cylinders.
Offline shrinker
    • SmartCarby
« Reply #5 on: 01 Nov 2012 at 21:06 »
I notice that now, thanks for that.
Bruce Robertson
SmartCarby
Offline tck
    • old racer
« Reply #6 on: 02 Nov 2012 at 11:06 »
Does any know if this car type would fit (Terrys)
« Last Edit: 24 Dec 2012 at 17:48 by Dave »
Offline oily bloke
« Reply #7 on: 02 Nov 2012 at 19:27 »
You could use that if you use a lump of brass or some such to place over the valve head to take up the space between the valve dead and the valve cap aperture. This is assuming you don't have a detachable head.
I have fitted them by hand in the past as the spring is quite light but getting them out needs a tool. I adapted a long nosed mole grip used for welding. Works fine and causes no damage.
Hope that helps
Andy
Offline tck
    • old racer
« Reply #8 on: 12 Nov 2012 at 07:02 »
Serendipity!
Went to a 5 stall car autojumble at weekend and just to prove that with atojumbles size does not matter
there was a Terrys valve compressor just like the one I pictured above and unlike the £30 flea bay ones it was very cheap.
Cursory examinations show it will fit but its most closed position is a little to wide for comfort and needs a tweak with a screwdriver against the valve spring
more later when I actually get to use it
