Author Topic: S6 Big End Bearings  (Read 4221 times)
Offline Jonathan
S6 Big End Bearings
« on: 16 Oct 2012 at 05:33 »
Can anyone help with where I might purchase 5/16" x 3/8" big end Roller Bearings for my S6 project?
Have exhausted my enquiries with our local bearing shops.
Any advice appreciated.
Jonathan (Australia)
Jonathan H.
Re: S6 Big End Bearings
« Reply #1 on: 16 Oct 2012 at 06:38 »
Jonathan,
               I had similar problems when looking for rollers for a DT crank that I was trying to refurbish. I ended up having to grind down longer rollers (not so hard as it first sounds!). With regard to your S6 crank: 5/16 x 3/8 rollers are now very scarce (as you have found) but a company here in the UK can supply 8mm x 12mm rollers - these are 2 thou bigger than 5/16, so would give you the option of honing out the rods/ grinding the inner tracks. Shortening them to 3/8 is a bit tedious but quite easy. I made up a bush with an 8mm bore and an adjusting screw for the depth - with this held in the lathe chuck and a roller inserted in it, I then carefully applied an angle grinder to the end of the roller (with the lathe running at about 800 rpm). With a little practice, it's amazing how accurate this method can be. Having trimmed the rollers to length, I then used a fine flap wheel in a Dremel to polish the ends and restore the radius on the edge of the roller.
     The crank I refurbished has now done over 2 seasons of sprinting without any ill effects - so I guess it has passed the test!!
     If you go down this route - the company to contact is: Simply Bearings. They have a website where you can select the items you require and order on line.
     Hope this helps,
Offline ManfrerdSt
« Reply #2 on: 16 Oct 2012 at 10:22 »
perhaps at
http://www.peters-bearing.de
Regards Manfred
Offline Jonathan
« Reply #3 on: 16 Oct 2012 at 10:33 »
Thank you Eddie and Manfred.
Eddie, would you mind posting the Bearing Shop details please, as our bearing shops also don't stock 8 x 12 mm rollers.
I will compare prices and do what you did.  I have access to machinery to hone the rods etc.
Regards,  Jonathan (Australia)
Jonathan H.
Offline MRD
« Reply #4 on: 16 Oct 2012 at 10:57 »
Hi Jonathan
I think Eddie is referring it this company.
http://simplybearings.co.uk/shop/
Martin
Offline Jonathan
« Reply #5 on: 08 Nov 2012 at 09:29 »
Thanks all, have ordered 8mm x 12mm rollers.
I will shorten them and re-size the rods to suit.
I appreciate you advice.
Jonathan H.
