Author Topic: mk 5 rear mudguard (wanted)  (Read 2378 times)
Offline Ray Dodds
« on: 11 Oct 2012 at 19:13 »
wanted mk 5 rear mudguard.
Offline Mike of Woking
Re: mk 5 rear mudguard (wanted)
« Reply #1 on: 29 Oct 2012 at 14:03 »
If it is the same as a Mark 4, then I have got one. Needs a bit of welding / stiffening where it is cracked. Other than that is it pretty sound. I could even fix it for you at a local workshop / fabrication workshop if you want and don't have the facilities.
Mike
Offline Ray Dodds
« Reply #2 on: 29 Oct 2012 at 15:53 »
Hi Mike i can fix it no problem ,What do you want for it, Regards Ray.
« Reply #3 on: 04 Nov 2012 at 17:05 »
Ray,
50 and it is yours. Can post but that will be extra - unless you want to collect from Surrey. if you are interested then please e mail me directly on mike dot shone at tiscali dot co dot uk.
Mike
