Author Topic: T6 Chain lenth  (Read 2477 times)
Offline kmd
T6 Chain lenth
« on: 21 Aug 2012 at 21:30 »
Hi All
Can any one help me with the number of links on the front and rear chains on a S or T6 please.
Kevin
Re: T6 Chain lenth
« Reply #1 on: 22 Aug 2012 at 02:51 »
Kevin,
Unlike other spares books, the one for the t/S6 does not mention the number of links in the roller chains. The rear chain is illustrated and I count 91 links. However, since 14 through 19 tooth output sprockets were available, the number of chain links will vary to suit.
No view of the primary chain. Gearbox input sprockets could either be 39 or 41 tooth, depending on if it is a S6 or T6 respectively. So again the number of links will vary (assuming the original sprockets are fitted.)
Offline kmd
Re: T6 Chain lenth
« Reply #2 on: 22 Aug 2012 at 05:31 »
Thanks Doug
Re: T6 Chain lenth
« Reply #3 on: 22 Aug 2012 at 07:18 »
Hi Kevin,
              I've just checked the chain on my S6 - it has 91 links - thats a brand new chain with a 19T gearbox sprocket, 51 tooth rear sprocket and the wheel adjusted fully forward.
Offline kmd
Re: T6 Chain lenth
« Reply #4 on: 22 Aug 2012 at 16:36 »
Thanks Eddie
Mine is 19 and 49, High geared but with the 750 motor hoping this is going to be OK?
Kevin
