Author Topic: Tyres for a 1928 DT  (Read 2892 times)
Offline Rob
Tyres for a 1928 DT
« on: 04 Aug 2012 at 03:36 »
Can someone advise the correct tyre size for a DT?
Rob
Re: Tyres for a 1928 DT
« Reply #1 on: 04 Aug 2012 at 08:16 »
Does it have wired-on or beaded-edge tyres?
Offline Rob
« Reply #2 on: 05 Aug 2012 at 06:20 »
Leon,
Beaded edge.
Rob
« Reply #3 on: 05 Aug 2012 at 12:56 »
Hi Rob,
If they are original rims (about 23" diameter, about 2" wide) they are probably 28 x 2 1/2" BE. Up until recently, the only available tyre was a "button tread" tyre from the USA. These are available in Black or White, but they are expensive and neither tyre will last very long if used on the road - perhaps a rally or two! Brian Forth told me recently that Ensign were considering making a 28 x 2 1/2" BE tyre, which would be a good tyre. If you're in Australia, perhaps check with him whether this is really going to happen: http://users.chariot.net.au/~brianforth/BeadedEdge.htm . Or a local dealer if you're in the UK.
By the way, although 28 x 3 and 28 x 2 sound close, they won't safely go on a 28 x 2 1/2 rim.
Offline Rob
« Reply #4 on: 06 Aug 2012 at 03:11 »
Leon,
thanks for the reply. I have dealt with Brian before and will contact him.
Rob
