Author Topic: Assembly Drawings for a B29  (Read 2133 times)
Offline gazza5507
« on: 05 Jun 2012 at 14:12 »
Hi All,
I'm looking for assembly drawings for my B29, and related information, I have had some good help from the LDMCC how ever my main needs are assembly drawing for the motor, even if it is not exactly for a B29 as I beleave late model EW's are very simular, should any one be able to assist I'd be greatly thankfull...
Garry
Offline Alan
Re: Assembly Drawings for a B29
« Reply #1 on: 10 Jun 2012 at 02:08 »
Garry..apologies for not responding earlier but had trouble trying to directly respond..Alas I don't have any assembly dwgs and neither did the chap from Perth ( alas now deceased) who had a comprehensive library..I believe the top part is essentially the same as a similar period EW but not sure if EW's had the "Squish" cylinder head that was supposed to up the power....My oil pump was as fitted on much later 30's models and went straight in...The pressure indicator stands quite proud when first started but drops back to almost nothing when the engine is hot...Hope this helps..
