Author Topic: EW Timing Gear  (Read 2404 times)
Offline bruceb
EW Timing Gear
« on: 06 May 2012 at 20:20 »
Hello all. I have just had a problem with the small gear that drives the cam wheels. It has stripped the keyway and also the oil pump drive has unscrewed and damaged the thread on the crank. I have been told this is common in a Douglas. Does anyone know of this happening and the cause. Also does anyone have this part of the crank? Thanks.
