Endeavour - clutch side crankcase bearing oil seal
Started by Michael Scott, 20 Apr 2012 at 15:01
Michael Scott
I have been advised that as I replace the crankcase bearings I should also replace the felt oil seal with a garter seal.
Before I start blundering around the internet (or more likely going to my local seals distributor) does anyone have a specific recommendation.
