Hi Simon,
I know your bike its a flyier, its the sports model with detachable heads . Before you start it make sure there is oil in the timing cover yours has a sight glass on the front low down on the forward face this should show oil about half way up it. if not take out the oil transfer plug [ centre of timing cover ]and pour or pump some in this will enable the internal oil pump to get oil to the big ends as soon as you start up. Give the hand pump a couple of squirts till oil is seen dripping in sight glass on the tank top'.prime the carburettor, ignition about half way air closed throttle just cracked open and give it a kick , if its been assembled correctly it should go.
Clive
