George,
The front coupling doesn't have much of a lip to hook a puller behind, so the easiest way of dealing with it is to remove the '8' plate complete with the input shaft. Inside the box, the input shaft has the dogs relieved on one side to clear the layshaft gear, so you will have to turn it until the relief is at the bottom (easiest seen with the side cover removed) before the '8' plate will come completely clear. With the input shaft gear held in the vice, undo the coupling nut a couple of turns, then grip the coupling in the vice and release it. Keep working your way around the 6 splines (it takes a bit of patience!) until the coupling gives up and frees from the taper. The couplings can be very stubborn, but I haven't found one that doesn't give up eventually!
Even if you do manage to get a puller onto it, be reluctant to apply the hammer to shock it off - this usually results in damage to the oil retaining lip on the '8' plate (it's behind the thrower, so you cant see the damage you are doing!).
