Author Topic: oil pump?  (Read 4288 times)
Offline tom hoek
  • douglas A32 terrier 1931
oil pump?
« on: 03 Feb 2012 at 09:38 »
Hello bikers
 Have another question
 You know what this is for oil pump?  its from a  350 cc Douglas A32 1932
engine.
 And how it works?
 And how high should the oil level in the crankcase?
 see photos
 Greetings from tom
Larger view
« Last Edit: 07 Feb 2012 at 19:27 by Dave »
Re: oil pump?
« Reply #1 on: 04 Feb 2012 at 23:33 »
Tom,
The pump and timing cover is suitable for the A31 and A32. It is a dry-sump system, so there is no oil level in the crankcase. There is a oil level in the timing chest, sufficient for the lower cam gear wheel to dip in. The level is set by a drilled hole in the back wall. Excess oil flows into the crankcase chamber and is scavenged to the compartment in the petrol tank.
The oil pump does not supply oil directly to the crankshaft. It supplies oil to a spray-bar that drips oil into the path of the connecting rods. Shallow grooves on the leading edge of the crankshaft center web lead the oil into the side of the connecting rob bearings.
The attached illustrations should demonstrate what is going on in the three-stage pump.
« Last Edit: 14 Oct 2018 at 16:23 by Doug »
Offline tom hoek
Re: oil pump?
« Reply #2 on: 05 Feb 2012 at 19:10 »
Hello doug
Thanks for the pictures and explanations
 it is very clear to me now  :D
greetings from Tom
Offline Daren W Australia
Offline Alan Cun
Re: oil pump?
« Reply #4 on: 27 Apr 2016 at 09:38 »
Looks like the pump for 600 EW or E 29
