Serving Douglas enthusiasts worldwide since 2004
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Help
Search
Login
Register
Douglasmotorcycles.net
General
Douglas Motorcycles - General Discussion
Rear brake assembly
« previous
next »
Print
Pages:
1
Author
Topic: Rear brake assembly (Read 3711 times)
JonathanJoy
Full Member
Rear brake assembly
on:
04 Nov 2011 at 16:15 »
Hi I've recently brought a 37 250 Aero. There was no rear brake assembly but it did come with the following plate. Question is it the right part ? If so what else do I need. I've noticed some machines appear to have an aluminium plate. I've an exploded diagram of the assembly so I definitly need the brake drum to go with it, any help would be much appreciated.
Kind Regards Jonathan
Last Edit: 08 Nov 2011 at 02:19 by Dave
Logged
Administrator
Re: Rear brake assembly
Reply #1 on:
04 Nov 2011 at 23:28 »
Johnathan,
Not a Douglas baking plate. From 1926 to 1938, Douglas predominately used a eight inch diameter expanding single band brake. Sometimes servo assist, sometimes not. The brake bands are near all identical except for the direction of operation being CW or CCW depending on the situation. There is some small variation in the cast aluminum backing plate and the length and stoutness of the operating arm, as the years went on.
A quick search of 'band brakes' turns up the following posts:
Article on the servo band brake.
https://www.douglasmotorcycles.net/index.php?topic=338.msg969#msg969
Relining 350EW brakes.
https://www.douglasmotorcycles.net/index.php?topic=2287.msg8267#msg8267
General comments.
https://www.douglasmotorcycles.net/index.php?topic=889.msg2907#msg2907
https://www.douglasmotorcycles.net/index.php?topic=1927.msg7072#msg7072
Brake arm and shaft.
https://www.douglasmotorcycles.net/index.php?topic=2440.msg8823#msg8823
https://www.douglasmotorcycles.net/index.php?topic=3431.msg12530#msg12530
[update links to https. 22Aug19 -Doug]
Last Edit: 22 Aug 2019 at 18:13 by Doug
Logged
JonathanJoy
Full Member
Reply #2 on:
05 Nov 2011 at 08:58 »
Thanks Doug,
I'll post a message on the parts wanted forum
Logged
podge
Full Member
Reply #3 on:
17 Nov 2011 at 11:45 »
Hi Johnathan
Did you get my spares list?
Paul
Logged
Print
Pages:
1
« previous
next »
General
Rear brake assembly
