Author Topic: 1950 MK 1V gearbox oil leak  (Read 2807 times)
Offline keith1101
« on: 11 Oct 2011 at 21:33 »
I have an oil leak from the main drive shaft. Can I replace the felt washer just by removing the shock absorber and drive sprocket?
Re: 1950 MK 1V gearbox oil leak
« Reply #1 on: 12 Oct 2011 at 07:13 »
Keith,
           To get at the felt seal, you will need to remove the sprocket/shock absorber assembly. Then undo the 6  1/4"BSF nuts around the final drive assembly. The whole final drive can then be removed from the 'box (you may need to use a large drift against the RH end of the shaft to start it moving). With the assembly removed, you will see the bearing is retained by a large nut and tabwasher - with these removed, the shaft can be pressed out of the bearing, revealing the felt seal. The shaft also has a short sleeve pressed onto it that fits the bore of the felt seal - this may also need replacing. Always make sure you oil the new felt well before assembly - a dry felt can quickly cut into the steel sleeve.
Offline keith1101
« Reply #2 on: 12 Oct 2011 at 09:42 »
Thanks for info Eddie.
