For Douglas enthusiasts worldwide since 2004
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Help
Search
Login
Register
Douglasmotorcycles.net
General
Douglas Motorcycles - General Discussion
Copper gasket dimensions
« previous
next »
Print
Pages:
1
Author
Topic: Copper gasket dimensions (Read 4426 times)
Ian
Master Member
on:
19 Sep 2011 at 07:43 »
I am going to replace the copper head gaskets on my E28 (EW600). Does anyone know what thickness the sheet should be ? Also, were they originally just a ring that fits inside the head bolts or do the have holes for the bolts ? I also notice the LDMCC has them listed for S6 - are they common between the models ? (would save a bit of work
Logged
Alan Cun
Master Member
Re: Copper gasket dimensions
Reply #1 on:
19 Sep 2011 at 10:53 »
Yes Ian the gasket on the E28 and E 29 is just a continuous ring the shape of a piston ring about 1/16 thick and fits within the head studs. The S 6 gaskets are flat copper asbestos gasket with holes for head studs.
Not sure which would be the easy way to make either from sheet or plumbers copper rod which is easily joined at the ends and the ring then flattened very tricky whichever way.
Maybe laser cut could be a way too.
regards Alan
Logged
Ian
Master Member
Reply #2 on:
19 Sep 2011 at 10:55 »
Thanks Alan
Logged
Alan Cun
Master Member
Reply #3 on:
19 Sep 2011 at 11:10 »
Hope that helps somewhat and yes forgot to mention. My mate Des loaded the OC on the ute yesterday with the first task to make the tank from the patterns you supplied and what we think it should look like. Then we hope to finish it off. It will be great to see it finished after resting in the shed for the past 30 years unfinished.
Logged
Ian
Master Member
Reply #4 on:
19 Sep 2011 at 23:50 »
Yes - having two OCs on the road will be awesome !!
Logged
Administrator
Reply #5 on:
20 Sep 2011 at 00:46 »
Ian,
3.312 o.d. x 2.938 i.d. (or nice fit on spigot) x 0.062 thick copper. The originals from my F28 vary from 0.057 to 0.063 thick, which is why the were replaced by rings cut from aluminum sheet!
Logged
Ian
Master Member
Reply #6 on:
20 Sep 2011 at 00:51 »
Thanks Doug - so aluminium works OK ?
Logged
Administrator
Reply #7 on:
20 Sep 2011 at 00:56 »
Ian,
Well, never got so far as running it... But I did also use aluminum sheet on the Mark 3 Sports, after I got tired of blowing out the modern cardboard gaskets, and that has lasted over fifteen years.
Logged
Print
Pages:
1
« previous
next »
General
